OFFICIAL RC18MT/B/T THREAD
#3302
MI
RE: OFFICIAL RC18MT/B/T THREAD
ORIGINAL: MiniMicroTrackMonster
what are the best tires you guys reccomend if i want to hit the track?
#3306
KY
I found some ALMOST perfect size metal mesh that looks like it will work perfectly in the stock chassis. I can update with picks if anyone wants.
#3307
MI
ORIGINAL: tylerjackson
#3311
DOes anyone have know which hobbycity lipos 2s and 3s will fit in the m18t?
I have purchased so many that dont end up fitting the car I want?
thanks
thanks
#3313
MI
ORIGINAL: katzcratch
thanks
thanks
#3314
MI
ORIGINAL: neyou86
whats a used rc18b worth? ive been kinda wanting a mini and a guy said ot shoot him an offer.
#3316
MI
ORIGINAL: neyou86
its 100% stock
its 100% stock
#3318
MI
The hobbycity lipos arent always as they advertsie in terms of size, was wondering if anyone had used a specific one.
#3319
CA
What I do is I put servo tape on the bottom of the battery strap and then stick on a piece of grippy, soft rubber from something (old rc10t4 tire, jelly shoe insole, one of those kitchen jar grabbers, ect). Then, as long as the battery fits on the tray, the strap will hold it down and keep it in place even if it is a little small. Just make sure your battery's maH and c rating are high enough and you are good to go.
#3320
Will these springs:
http://www.toadztoyz.com/Shop/Contro...29240231236243
work in these shocks??
http://www.toadztoyz.com/Shop/Contro...37238231238241
#3324
to drill or not?
anyone running 1/18 road rage pro line on bully or revolver rpm rims?
if so did you drill holes in rims to vent air for better traction,or not for better air pressure?
is it the same for the offroad tires and rims as well,vented rims for better traction less bounce?
thanks
thanks
