OFFICIAL RC18MT/B/T THREAD
#3551
RE: OFFICIAL RC18MT/B/T THREAD
ORIGINAL: trx1
well, gotta get another esc, neighbors kids broke it.
also gotta get a remote bat cover! cant find one on the AE site....??
Jackedman almost sounds like the motor was defective. I think one of our other members had a similar issue on a diff RC, and it turned out that one of the motors leads were not making good contact
#3554
ORIGINAL: Jackedman
SyCo_VeNoM
but once its has a little bit of a roll it gos like stink
SyCo_VeNoM
#3557
CA
Still have and run both of my RC18's (R&B). Seems 18th scale as kinda died off but I <3 these cars! Dont plan to ever sell them
#3559
My Feedback: (81)
VA
Some cogging is normal in certain setups. Maybe it's your gearing.
Oh.... you said you upgraded the esc. What esc are you using? A poor esc can definitely cause cogging.
#3563
ORIGINAL: Jackedman
the only lower amp esc i have is a airplane one will that work????
btw you can try a higher amp esc if you have a ground based one
#3565
My Feedback: (81)
VA
It is definetly a problem between the esc and motor. Some cheap motors will cause the cogging also. I'm betting that a better esc will take care of the problem.
There are quite a few nice turnigy escs out there.
#3566
Im thinking that is the problem. the cash flow is all called for at this point in time but i was thinking of getting the 18amp trackstar esc for it and go from there once i have some money again.
#3567
Hi,
I am planning to buy an RC18-B2 but have almost made the decision to go kit form (RC18-T2/B2). Depending on advice I may sway to the RTR.
~ Can anyone advise whether I can use my CC Mamba MMB25-CM2068 and ESC ?
and if so....
~ What battery arrangement I can get away with ?
~ What servo should I go for ?
I cannot find any threads with this combination. This could save a small fortune on sourcing a new brushless motor. I intent to use my existing 2.4Ghz Tx and buy an additional Rx
Many thanks
Dan
and if so....
Many thanks
Dan
#3568
It will work and should be a good powerful esc/motor. I run a hitec servo. I can't give good advise on a battery. I run the turnigy 800 mah 2s packs I got with my truck but you could use something double that size.
#3572
After a roughly 20 year hiatusfrom R/C, I picked up a RC18T2 Brushless RTR. Ibought some Duratrax DTX 1600 battery packs for it and was wondering if anyone on here knows where I can order an adapter that will connect the male mini connector on the Duratrax battery packto the male Dean's plug that is stock on the RC18T2. Ihave zero tools or technical savvy to make one myself so I really hope one exists.
I gotta hand it to Associated on this thing, it is an engineering masterpiece and has come a long way from my gold chassis RC10 from back in the day and the price deflation is amazing - $200 fully RTR with a full set of ball bearings would have been unheard of 20 years ago.
Thanks for any help.
#3575
OH
Skid plates? I found this on ebay and was wondering if anyone uses one? If so do you like it?
cgi.ebay.com/ws/eBayISAPI.dll
