RE: Nitro Models Extra 330 90 - 63
I think I'm using the heavy duty dubro clivces with the sliding metal clip, along with the threaded rod control horn on the ailerons, and regular nylon clevices on the elevator. I used a belcranck on the elevator, with the supplied dowel but new rods, I epoxied the heat shrink tubing on and supported the rod with balsa 1/4" squares.
There are little tubes in the back of of the fuse that you need to thread the pull pull cables through, they are hard to see but they are there, just keep looking and I think they are pointed out earlier in this thread.
I'll be interesed to see if a 91 4 stroke will be okay in this plane. I started wth a 75 2 stroke and it was dissappointing, hence the 91 two stroke now.
Good luck!
