RE: rd8000 setup questions
For flaps, to do what you are describing, it will be vastly easier to just use a Y-Harness. You can use 2 separate inputs for Ailerons (Use the differential aileron setup as described in the manual), but Flaps will be easier with a Y-Harness.
