no big mods realy.
im using savox 256 servos, good strong servo and enough for the job,
elevon horns are glued as per instructions and also bolted through the elevon, plastic plate on the top surface to spread the load. didnt want to rely on the glued joint!!!!!!!!!!!
made the air intakes bigger and added another above the esc.
hacked a good amount of foam out to fit the 6 cell lipo, also making sure enough air can pass by it.
didnt realise how much fun you could have with a piece of foam,,,,,,,,,,,,,,,,,,,,,,and dare i say it,,,,,,,,,,,,,,,,,,,,,,,, its faster than one of my gas turbines!!!!!!!!
poison is good for you,,,,,,,,,, especially in these amounts!!!!!!!!
