RE: You Can Do Engine Problems
Shift some foam around, a hobby knife, Razor saw, Chainsaw or Class 1 explosives fix the problem, I will not argue the semantics of the word simple.
Exactly because they are beginners is all the reason to start learning right now and fix the problem. So much repetitive grief is caused by this day in and day out even when it is carefully explained.
John
