RE: Getting started in pylon?
The TTpro .40 comes with a backplate - lots of folks remove them to use the Jett or Nelson backplate mount. Others use the factory backplate and use a mount that (I believe) comes with the viper, which is simply a flat plate with holes in the right places.
If you've picked up a used engine, are you meaning it has no backplate at all?
