RE: Volcano pinion gear size
Hi,
Thanks for your detailed reply. I get most of the things you have mentioned, but I have two questions about the things that you have stated in your post.
1) What is a VXL system for Trexxas? I looked up and Trexxas make many different vehicles wih VXL label i.e Slash VXL and E-Revo VXL. So what is a VXL system and can I upgrade my Redcat Volcano to use it?
2) You have suggested toraise the suspension; which is exactly what I had in mind. Do you know what would be best way to raise the truck to get more ground clearance. Even if I find longer shocks (I am not even sure if I need longer shocks) I would need other suspension parts to go with it, right? So what would be right place to start looking toraise the suspension.
Again thanks for your time.
