Originally Posted by
gsmith6879
They do require a puller and some mechanical skills but well within most modelers ability.
I was just guessing that you needed a puller. I read no manual comes with the starter. But from looking at the pictures on how it's made, it did not look to bad on the install. I guess you have to re-time the motor. I have two manuals on the DLE111 one has no info on timing and the other says timing is to be set at 40degrees. I would guess timing would be more like 28 to 30 degrees.
To bad you did not make a u-tube on the install, you would be a hero do to no manual.
