Hello,
I am testing a bird-like glider I have been building, which looks like an eagle, and flies like a trainer glider. Total weight inc batteries : 2.3 kilograms
I just ordered the SK3 1000kv, as it is should be good enough those maiden test flights and potential crashes.When plane will be tweaked properly, I will replace it with a higher quality motor.
My question is : I have a couple of Plush 40 amps in my drawer. Can I use it in 4S ? It says burst rates up to 55A, and there is no way I will ever push the throttle to the max.... Or should i forget about it and order a say, 60 amps ESC ?
Thank you very much
