Originally Posted by
Dumanyu
Motor is installed. All it took was a .75" nylon washer with an inner diameter of .504". Works perfectly and doesn't interfere with the vents. Washer is about 1/8th inch thick. See pics below.
Without the nylon washer, you were not able to position the pinion gear correctly?
