Help with Transmitter Setup - Futaba and new PowerPak SE ECU
I am trying to complete the “Transmitter Setup” on my two, new Bee80 SE turbines with the new PowerPak ECUs.
I have a Futaba 14MZ with the throttle direction set to “Reverse”. The ATV for the Throttle channel has the upper and lower Limit to 135% and Travel set to 100%.
I “taught” the PowerPak / ECU based on the new manual. Then I set the transmitter Failsafe (which is set to -135% - the lowest value possible).
On the GSU it shows 1103 microsecs at low throttle, high trim. On the GSU it shows 956 microsecs at low throttle, low trim and is in the “Green Idle range”. When I turn off the transmitter and put the Receiver in Failsafe, the GSU shows 956 microsecs is in the “Green Idle range”, not the Red Failsafe range.
These are my first JetCentral turbines and the ECU learning procedure is different than other turbines I have set up over the years.
Any help getting the GSU to show the Receiver in the Red Failsafe region would be appreciated.
Nick
