When is the last time you saw an ignition run away and "take out" a battery?
Andy,, that would be never,,,
Originally Posted by
Murphey
Actually, the only ignition module I've see fail did just that...it died and so did the engine...no huge current draw...no current draw at all. The ignition module failing and draining the battery is the argument used against dual use of a single battery...probably has happened, but I've never seen it. I guess I was skeptical at first so I tried it on a test plane and it worked...for me...so as I built new planes, the single battery and Tech-Aero IBEC is all I use. In fact, I don't even use a mechanical switch for the ignition...just the IBEC plugged into the receiver. That's just MY experience...others may have experienced less than wonderful results...
M
Same here,, no second battery, no need for a second switch
