bjw4072,
Thanks so much !
Once I did what you described, I was able to get it out of the Double Action Mode and into the Single Flip Mode.
Here is what I did:
I am using the JR 28X transmitter.
I am using switch J for my ignition kill switch.
I use switch I for my choke servo.
It's like this just because all of my planes are setup this way...
I went into travel adjust for Aux6 (my ignition kill channel) and set the endpoint to 100.0% and 0.0%.
This got the Single Flip Mode working.
Then I went into Hardware Setting and touched switch J, on the screen.
Then under Reverse, I set it to ON.
Switch J is actually a three position switch. I have it setup so that Pos 0 & Pos 1 are ignition on and Pos 2 is ignition off. I figure two switch positions with ignition on is safer than just one. Less chance of turning it off by mistake.
