Originally Posted by
Thai Tiger
Hi Loukos, from the photo to looks like the saddle tanks are in upside down.
I had to epoxy the originals closed & cut new holes to miss the former on the FWD section. Otherwise the main tank is too high, resting on not much & when you pull G's it will split the FUS under the wing. Ask me how I know this.....
Thanks Thai, I was scratching my head about that one...I was sure they were upside down, but then when I put them the right way up the tanks fittings are obstructed by the from FUS former...another re-engineering that need to be done. I will also make some sort of rigid mounts for the tanks to hold the weight of them so as to take it off the fuselage.
Regards Luke
