Originally Posted by
Dansy
One question on your harness, with this number of pins...you must be sharing power or ground to servo’s and retracts?
yes. the flap servo and aileron share the power in one pin. I had tested it before I produce it. I make 12A in one pin for more than 5 minutes. it is no problem.
usually the stall current of the servo is about 4-5A. Even both flaps and aileron servo was stalled. the current is about 10A. so it is no problem.
