Finally got started putting the bigger Tiger together. As you can see in the photo, the wing is considerably bigger. Covering on this one has some loose edges and even some exposed wood. Other than that it looks great. The bigger version also comes with unhinged surfaces and CYA hinges supplied. I liked the smaller version as it has normal hinges that were pinned in, and I am replacing the supplied CYA hinges with Dubro standard hinges. Should have two Phoenix Tigers in the air by spring.
