Originally Posted by
Blueyonder
Thanks for the updates... Nice looking Tigers. :-) A bit of a slow go here on my Tiger Jr. I found the slot on one wing panel is a bit tight for the wire landing gear so trying to figure the best way to resolve that.
Too bad on your wing hole issue... I'm sure that's a bit of an annoyance. Good luck on the correction with that.
I have run into that issue in the past regarding a narrow LG slot. You can use a wire of the same diameter, or even the gear you plan on using, to make a tool. Sharpen the end with a file or grinder and use it to chisel away the extra wood. You end up with a nice tight fit.
