Next steps are to install the wing trailing edge hard mounts. Still working toward getting the jet on the wheels to check the gear toe in.
Projecting the location of the trailing edge wing bolt. The plan is to drill all the way through the wing root to the flap side and install a 10-32 blind nut.
There is a 1/4" gap between the fuse and wing root when the wing is bolted on. I installed a spacer so the bolt will hold the wing firm with out pulling it in.
Pilot hole drilled from outside in spacer location
Wings installed and bolt hole drilled from inside out through wing root
10-32 blind nut installed with bolt
Blind nuts secured with hysol
Wings installed ready to mount gear
