The design is to use 8mm carbon tube guide pins ant 10, 2, 4, and 8 and 1/2' x 1/8" magnet discs at 12, 3, 6, and 9
Layout done and ready to tape the blanks together to cut two identical formers at a time.
Scroll saw cutting started on inside cutout.
After inside cuts were complete tape was applied to the inside to keep the blanks together when outside cut made and tape falls off.
Formers cut out and ready for dry fit and drilling on drill press. I will leave the tape on until holes for the guide pins and magnets are drilled to ensure good alignment. Unfortunately that will be a few days because my magnets and carbon tubes have not arrived yet.
