Looking at the differences in the thrust line on various pod mounted power plants it seem like it would be easy to whip up a pod with an adjustable thrust line. With a brushless motor and a well balanced prop you wouldn't have to contend with things vibrating loose. A pivot near the top of the pylon and a couple of screws to lock it down would probably do the trick.
