4" spacing works great, and I think is pretty standard. But, I can accommodate anything that might be needed by the ribs. Also, given that there is slight dihedral, you might consider building the dihedral into the 1/4 holes if the ribs can accommodate it (Like Al Rabe, if you familiar with his work) allowing for building the entire wing at once, or left and right halves.
Thanks again,
Jim
