Aileron hinging finished!
Aileron tips extended to match the wing tips and sanded to shape.
Small cut out made with scroll saw to attach the hinge wire.
Hinge wire glued into the block and screw used to secure the block to aileron tip.
A small block of wood was glued inside the aileron to catch the screw.
Aileron hinge wire secured to aileron tip. Button head screw is a temp. I will countersink the screw head flush with the tip when I get the proper #2 x 3/4" flat head screws and then sand the tip to final shape.
