Originally Posted by
Shabbernigdo
Tamiya for all 3 questions.
OK, no problem. Tamiya uses the same TU for KT and T1 ,only difference is the stand offs.
Stand offs, original equipment on a new Tiger 1 mm transmission, three for each unit, length is 9.3 mm. You can vary the length from 9.2 to 9.4 but nothing outside of that variable and make sure both units have matching standoffs.
Transmissions installed in Tiger B, aka Tiger 2, are 5 mm wider than for a Tiger E, aka Tiger 1. This difference is made up by the transmission installation holes in the wider Tiger B hull. Also, for Tiger B take the stock Tamiya track pins, remove each one link by link and insert them from the outside, not the stock inside. Reason being sometimes the pins will walk out a hair with time and the clearance at the rear hull plate is minimal as the tracks co around the idler. If the pin is on the inside, it will catch on the hull rear plate and eventually bend the pin or break the track link. With the pin installed from the outside this problem is eliminated plus you can easily see a pin that has decided to wander on out a mm or two.
For Tiger E, this pin problem does not exist as far as I know.
