Turbine hatch latches installed
Turbine hatch latches installed as before with slot and latch pin hole cut and then tacked in with medium CA.
Latch pin holes marked with black paint as before.
Latch pin holes drilled.
Latches installed and working ok.
View from the rear
Plywood donuts installed as before and tacked in with 5 min epoxy. Will secure with hysol later.
