RCU Forums - View Single Post - SIG Four-Star 60 Build
Thread
05-28-2019, 03:18 PM
169
VincentJ
With the fuselage covered in red, I want to apply a white accent stripe cut from UtraCote. Here you see me prepping the base using Alcohol to clean the area.
With the base now clean and dry, I sprayed the area with plain (blue) Windex. The stripe will be laid over the wet Windex making it lay flat on the red base. It will
not
as some believe activate the glue on the UltraCote and make it stick...
With the stripe now on, it can be easily positioned/moved exactly where you want it. When your satisfied with its position, take an old credit card or an old playing card and squeegee the excess Windex from between the base and the stripe. Wipe off the Windex with a dry paper towel and repeat the squeegeeing until you've gotten all of the Windex out. At this point the stripe should be making 100% contact with the red base covering.
All that's left is to set your iron at about 200 degrees to activate the glue so the stripe can be secured. Don't use too much heat or you will cause air bubbles to form between the coverings and then you'll have to pop them to get them out.
I've placed the cowl in position so I can get the exact location of where to spray the white epoxy paint to extend the stripe.
05:02 AM
Reply
Like
VincentJ
View Public Profile
Send a private message to VincentJ
Find More Posts by VincentJ
View iTrader Profile
