Doors attached to hinges and door horns
RIght side open after tack gluing to hinges with medium CA
RIght side closed, flush with wing skin, and aligned with the lines for the main strut door
Same for the left side
Ditto on left side...
Both doors posing for photos. Getting the first one on the right took about 5 hours and 45 min on the left side, but it's done.
I found some old phenolic horns in the parts box left over from a Kangaroo kit I built about 20 years ago. I cut them off and they worked perfect for the gear door horns
Center lines marked
Slots cut
Horns glued in with medium CA. Holes are about 25mm from hinge line approximately equal to holes in servo arms
