more/different slowstick build questions
The Slow Stick is my first build, I realize it isn't difficult, but still I have some questions that I'd like to ask.
The instructions give two alternate ways to build the tail. One attaches the rudder/elevator with only a piece of double sided tape, the other uses screws to hold them on. I used the double sided tape method -- is that strong enough? Should I go ahead and drill and add the screws as well? (And while we're at it, at one point the instructions in the same section tell you to cut the main tube and then reattach it with a connector. *Why* would anyone ever do that? I can understand attaching the tail feathers only with screws, but why cut the tube?)
As long as the center of balance is appropriately placed on the wings, is it important how far the wings are from the motor? Mine are set a couple of inches or so back from the motor, and CB seems okay, but I'm wondering if it would be better if they were further forward.
Sean.
