RE: GP .46 Ultimate Bipe
Do you mean that the struts are loose between the ribs that sandwhich them in your lower wing? If so, don't worry about it yet. The covering will likely add enough thickness to snug them up. If not you can put a couple layers of clear packing tape om them until they're tight enough.
