RE: Dynaflite Talon build
Allthough its not taken much time to build to this stage, getting the time to work on has been a problem.
The wings, ailerons and fuse/hatch assemblies are ready for final sanding and skins. The fit for the hatch to wing should be done in slow steps, getting a good fit is not hard but requires a good deal of attention. The Sub Trailing Edge (STE) is only 1/8 inch thick, attatching the hinges to it after covering the two-peice aleron(s) will require sme additional support. IMO
