Will this work?
I have a good digital multimeter what will do a lot more than I know how. I don't think that it can test my RX battery under load though. This is my plan:
Plug a lead into a spare channel on the RX, remove the white signal wire, and solder on a plug which I can plug my multimeter into. If I turn on my receiver and operate all of the servos at once while the multimeter is plugged into a spare channels's positive and negative leads, will it show what my battery voltage is under flight conditions? (approximately?)
