RE: Dominator 200 Build
If I can possibly wedge it on there, I would like to hang the .15 CV-A on the nose. Too bad Jett doesn't make a .15. It is a small plane. The firewall is only 1 1/4" high and 1 1/2" wide. I am about to check the Dimensions on the O.S. website. Going to be a very light build, I can already tell. I have pulled out the plans and checked out all the contents of the box. I already have some mods in mind- specifically rounding or angling the wing tips (something like a big-stik), as they are completely square on the plans. Sheeting the entire wing, and putting a more dramatic angle on the verticle stab. Of course, I will not be puting a rudder on this plane. I am also toying with the idea of changing the elevator to be a one-piece assembly, and re-routing the elevator pushrod to come out the rear of the fuselage instead of the side. I am definately going to carbon fibre the wing spars, as there is no plywood in the wing whatsoever, and it was meant to fly on an .049.
