RE: SUPER REAPER MAIDEN FLIGHT SOON NEED ADVISES
dont worry they are a doddle to fly. shutting the turbine off to land is good advice but wait till you are used to the model otherwise you may over or undershoot. just be prepared for a few bumps on landing. if you set the nose wheel low so when it is sat on the ground the aircraft is at a negative angle of attack it will land better with no bounces.
