RE: Showtime
Has anyone else had a problem with snapping out when elevator is pulled? I am having a tough time trying to fix this, almost lost it yesterday when pulling out of vertical down line, I forgot to be very light on the elevator,pulled too much up and it snapped to right once, then on second attempt it did it again,lucky I was high enough to save it on 3rd try, I had to cut throttle and just squeeze a little up to get it level. I double checked the latteral balance,elev. throws-I did notice the right elev. as traveling more, so I fixed that but it still does it. I tried elev.-spoileron mix(100% I think), that didn't matter. I did try doing outside loops and it didnt seem to do it that way,not sure what that means? I'm not sure what to try next other than move the CG back some more,which I was going to do anyway. I did notice some warp in one elev. half but it flys straight when level& ailerons seem to be set the same. Any ideas???
