sounds great but try to find a 3d plane thats in a kit and not a profile.
Amen my brother!!!
If i can change the subject a little and add a quick little question about geometry / setup etc. So what about ATV's or endpoints. Should you max out your end point and adjust the arms mechanically to achieve your recommended throws? With 1 inch arms, to stay within 1:1 ratio, he surface must be at one inch? So on the showtime where they tell you to thread the control horn to this specific height, that makes the 1:1 way out of whack.
The instructions also call for some 50 deg down elevator throws, and i can barely get 40 deg with 1 inch arms with the control horn at their recommended height.
So what arms / throws are you guys using?
