Katana S 3D Foamy
My Feedback: (15)
FL
Katana S 3D Foamy
Here is my latest toy. Took two days to build and two sheets of depron. 10.25oz complete without the battery. 13oz with a Thunderpower 1320mA 3s battery.
I hope to get a color scheme on it this week sometime.
This is replacing my trusty Diablo 3D, which has been flown more times than I can remember.
Plans from 3DFoamy.com
Wingspan = 39.25" (Full Length of Depron)
Weight = 9.5-15.5 oz
Power = 24-39 oz
Radio = 4-5 Channels (I am using only 4 to save weight)
Area = 301.0 sq in.
Loading 5.1-7.9 oz/sq ft.
I added a CF rod down the length of the fuse for extra support. Installed one aileron servo instead of dual servos. I also changed the design slightly to accept a radial mount outrunner design instead of a stick mount design.
Derrick
Power = 24-39 oz
Area = 301.0 sq in.
Derrick
My Feedback: (15)
FL
RE: Katana S 3D Foamy
Thanks Edgeomatic,
I've been flying the Katana for a few days and loving it.
I flew Thursday afternoon and the elevator control horn popped out ending up with a smashed nose from about 300 feet up doing a blender. There wasn't too much damage except for the motor mount and a few other places. Overall, I'm really pleased at the strength of the plane with the CF rod down the fuse.
1st two photos shows damage, 3rd photo is fixed nose and ready to fly again.
My Feedback: (15)
FL
While I was fixing my Katana's front end, I thought more about my color scheme and started on that Yesteray.
All the designs were free handed cut out the same as I did my Diablo 3D a while back. It takes a little longer to do, but I think the overall result is good.
I think I will add landing gear to the aircraft also.
Hope you enjoy.
Derrick
Hope you enjoy.
Derrick
My Feedback: (15)
FL
ORIGINAL: Gymnast
Which himax motor are u using? I have 2808-0980 looking for a home. Do u have any suggestions?
My 2812-0850 is slightly larger than your 2808-0980, but with a slightly lighter plane the 2808-0980 would be great combo.
Here are some links for what I think may be a good candidates for you if you are looking for a 3D plane also. The links below are all using a 2808-0980, so they are great examples for you.
1) Vulcan 3D EPP
Using only a 2-cell pack only, so a 3-cell would be even stronger. There is a video at the bottom of the page also showing what the plane will do.
http://www.rcgroups.com/links/index.php?id=4870
2) 3DX Mini 3D
Using a 3-cell pack. There is a video at the bottom of the page also showing what the plane will do.
http://www.rcgroups.com/links/index.php?id=4844
3) You can also go to www.3dfoamy.com and look at their free plans which is where I got my Katana S 3D plans from for free. Be sure to look at the "Critical Mass" plane plans. This plane weighs 4-6.5oz. No video for this one yet.
"Critical Mass" **FREE**
Hope this helps...
Derrick
My Feedback: (15)
FL
ORIGINAL: VictoryRoll-91
The Katana S, came with a bunch of electronics too
VA
I know most people don't put landing gear on these small foamies, but I do. I think it's more fun, try touch and goes without gear. Besides they last longer with landing gear. I had 43 hours of flight time on my Eflite Ultimate when I decided to retire it.
FWIW, I have no problem taking off or landing at my grass flying field. The club keep sthe grass cut fairly short, but even when 2-2.5" long it works out fine.
Nice looking plane DTB. I'm waiting for John, 3D Foamy, to cut an Advantage bipe for me.
Something to consider is that I recently tried a TP 910mah 3S pack and have since changed over from my 1320mah packs. I dropped 1 ounce in weight and lost only 30 seconds of 3D flight time, but the performance improvement was the real payoff. This flying my now 12 and 14 ounce AUW with battery planes.
VA
It might, but I always find on 12+ ounce planes 3S li-pos provide a lot more power. I have 1 2S li-po and it never gets used. Actually I am gonna give it to a buddy of mine for his Slow Stik.
My Feedback: (15)
FL
Yeah, I agree. I had a 3-cell 1320 and had a bad cell in it that went bad. I made it into a 2-cell 1320. It flew the plane fine, but suffered greatly in the power department in comparision to the 3-cell. If you are going to do more than just fly the plane gently, I suggest 3-cells. 2-cells won't give it that humf.
My Feedback: (15)
FL
Is the Katan S a real difficult kit to put together?
My Feedback: (15)
FL
Since I bought the kit, are the spaces for the servos pre cut?
DTB....did you use 6mm Depron. Where did you buy it? How much plus shipping? I have a power plant and radio that I will take from my Tribute. Its AXI2205/26,TP3s1320,phoenix25,Spectrum dx6 radio with 4 servos. If that plane is 10.25 oz, as you stated I will have a lot of power to burn. Oh did you buy that decals from the web-site.
My Feedback: (15)
FL
ORIGINAL: eugenefelisco
All the decals on my Katana S were hand cut by yours truly. I didn't buy any decals.
MI
What did you guys use to hinge the control surfaces on your katana? I'm redoing mine for the third time because they always seem to pull to far away, thus, they get flimsy, and flap when I test the prop. Also, one of my ailerons goes up a little higher then the other does, it seems to have more throw, is this going to prove to be a huge problem in the air?
My Feedback: (15)
FL
