Seagull Edge 540 60 SERVO Help
MI
I just finished putting together my seagull edge 540. I was wondering if I should use metal gear servo's on the plane. The recomendation is a digital 811. Has anyone built one or flies one? What combo's are you using. I have a saito 100 engine mounted to it with a apc 16x4 prop. Any help or advice on this plane would be great. Thanks JOE
NY
RE: Seagull Edge 540 60 SERVO Help
hey JOECROW
I have this plane I run a Eflite Power 60 with 6s li-po 16x8 xaor prop. true turn spinner, Carbon fiber wing tube, JR DS821 on alerons / Elevators.
JR ST125 on the Rudder set up Pull Pull. JR1600 mHa 4.8v RX battery, spectrum AR7000 RX. the plane with batterys weights 8.2lb
the plane flys real nice . no problems with servos I allways use a MG servo on the rudder
the JR DS821 are 70oz
the JR ST125 are 125oz
