YS63s & 3styla
RE: YS63s & 3styla
got a ys.63 in my flip, thinking of getting another in september you put the .63 in, let me know how it goes. For £80 you just can't resist it.
RE: YS63s & 3styla
Nearly finished mine, just got to sheet the back end and cover install radio gear and motor and fly. Got a west .50 ti for it too. Only using 3003's alround, but thinking of running a 6v rx pack, that would give me 5kg of torque, and maybe upgrade the elevator to something special. Nephew's is using a MDS .40 in his, might hold up, but it's a good experiment.
The build of the wings in straight forward, simple ribs, spar and plan procedure. But worried about the twisting in the wings, they're easy to twist. But a novice should be able to build this no probs.
Fuse is so simple. did mine in about 30mins. 6 formers and a 2 1/8 side's reinforced with light ply and some 1/8 squ stringers + sheeting.
That ele is huge, you don't appreciate it till you've built it.
RE: YS63s & 3styla
I noticed when seeing the 3Styla flys that it does some perfect harriers, and I was thinking that is this because the wing is below the thrustline?
If a wing is on the thrustline it would be still genrating lift wheras a low winger would genarate very litte and hopefully be more prone to stalling, which is what you need in a harrier right?
Also one of the RCWorld people mentioned they chopped the tips off and it wing rocked in the harrier, so a combo of these two elimnate it or is it something else?
