RCU Forums - View Single Post - YS63s & 3styla
Old 07-16-2004 | 06:10 AM
Rhilluk's Avatar
Rhilluk
Default RE: YS63s & 3styla
Nearly finished mine, just got to sheet the back end and cover install radio gear and motor and fly. Got a west .50 ti for it too. Only using 3003's alround, but thinking of running a 6v rx pack, that would give me 5kg of torque, and maybe upgrade the elevator to something special. Nephew's is using a MDS .40 in his, might hold up, but it's a good experiment.
The build of the wings in straight forward, simple ribs, spar and plan procedure. But worried about the twisting in the wings, they're easy to twist. But a novice should be able to build this no probs.
Fuse is so simple. did mine in about 30mins. 6 formers and a 2 1/8 side's reinforced with light ply and some 1/8 squ stringers + sheeting.
That ele is huge, you don't appreciate it till you've built it.
