52" FUSION BUILD HELP
I am putting the finishing touches on my 52" OMP Fusion when I noticed that the wire ties connecting the tank to the plane are in the way of the throttle servo cut out. What can I do?
RE: 52" FUSION BUILD HELP
Take some pushrod wire and bend a U with 90 degree corners(1 above the servo and 1 under the servo) Put them through the holes and bend hooks on the ends,then rubber band the tank on.
WA
I had the same problem. Here's how to fix it. What you do is to put the wire tie through the fuse from the right side and the stub end of it will snug up against the fuse. The strap part of it will go around the tank and back through the fuse in the other hole. Now take another wire tie and cut off the stub end and slide it down the wire tie to secure it up against the fuse. Now do that to the second wire tie. Basically, you'll have two wire ties with four stub ends on each one.
