 edge 540 identification >
Old 08-27-2007 | 01:22 PM
LANNYBOB's Avatar
Default edge 540 identification
can you guys tell me who makes this edge 540 i dont know
ID:	750865   Click image for larger version
ID:	750866   Click image for larger version
ID:	750867   Click image for larger version
Old 08-27-2007 | 01:32 PM
Default RE: edge 540 identification
Its the Hanger 9 edge which came out few years back and got discontinued... but is still marketed by minicraft in the asian market..
check out www.minicrafthobby.com.. there is a thread here on rcu do a search...
manyu
Old 08-27-2007 | 01:34 PM
ORIGINAL: manyu
check out www.minicrafthobby.com there is a thread here on rcu do a search...
manyu
Old 08-27-2007 | 06:18 PM
LANNYBOB's Avatar
thanks manyu i need a proper c/g thanks in advance
Old 08-27-2007 | 10:41 PM
My Feedback: (67)
Hello LANNYBOB,
I have the original H9 Edge 540 Manual that went with the kit, I will also give you the manuals recommended control throws
The CG should be between 4 !/2 to 5 1/4 from the leading edge of the wing, messured at the fuselage.
Standard Rate 3-D Rate (High Rate)
Aileron 5/8 UP 9/16 down 1 5/16 Up 1 1/16 down
Measured furthest inbourd
Elevator 9/16 UP 9/16 down 3 in. UP 3 in down
Rudder 3 1/4 RT 3 1/4 Lft 4 1/4 Right 4 1/4 Left
Measure at the bottom of the Rudder.
If you need a new set of wings and cowel I have an extra if your interested?
Hope this helps out alittle
NEDYOB
Old 08-28-2007 | 05:50 PM
LANNYBOB's Avatar
thanks nedyob thats great. your a cool guy
Old 08-28-2007 | 06:34 PM
My Feedback: (67)
Your welcome ! Glad to help.
NEDYOB
