Engine turning
I use a dowel with a leather disk cut from an old belt glued on end ,don`t need to be perfect when glued on, just sand sides while in drill press. I use watered down fine valve grinding compound or the red rubbing compound. Some of that type finish on old air craft was done with a cup type wire brush , did it to cover hammer marks left from making cowling
