RE: New to Electrics
I will get an ESU that is 1 size biger then needed. That Amp draw is set by the prop size.
the 600 is follwed by KV = RPM the motor will turn with 1volt.600 kv x 11.1 =6660 RPM no load.this would be direct drive 2700 v would be used with a gear box.Check out the electric forum there is a lot to learn.
Hope it helped.
