RE: Showtime
I'm having a problem keeping the rear stab. up tight to the fuselage. Had them tight to the fuselage when i drilled and tapped the holes in the tube, but after a couple of flights i get a little bit of back and forth play in them. I'm concerned that after an extended period of back and forth play, the holes in the fuselage will start to elongate. Anyone got any tips as to how to get the stabs tight and keep them tight??
