Switch the pos(+) & neg(-) wires. Put the pos(+) wire in the center. Signal and neg(-) on the outer sides.
Just remember that they are switched, if you decide to use them in the older receiver again. Otherwise, you may "let the smoke out", and they will no longer work without smoke.[
