RE: Honeybee King v2 tuner shop
Not a kit. I bought everything from helidirect.com I bought the following:
Esky 3100kv motor ($19.99)
Dynam 25A brushless speed control ($21.00) They currently show out of stock but carry the Dynam 18A speed control for $18.00 which will also handle the 3100kv motor.
Motor pinion set for 2.3mm bore ($3.99) part #ELE020. This comes with 9t, 10t, 11t pinion. This give you some room for experimentation. 10t work fine for my basic flight skills.
Total cost before shipping with the 18A speed control is $41.98 and add the cost of your favority battery connector for the speed control. I use standard deans on everything. The stock batts come with jst connectors.
