RE: ZDZ 40 RE F3A Soft Mount
Matt,
Looks like the rings are glued to the firewall side cap only as otherwise the vibration will not be damped. Right? The rubber is the key to damp the vibrations. You mentioned the inner tube of a lawn tractor wheel. How thick is the rubber material? Does the rubber glue to the rings? If so, at each layer or just to the outside of the rings?
Thx
