RE: Electric Osmose Building
Hi Isaac
If you haven't already, may I suggest you double check the stab incidence lines as mine are off. The left (looking from the back) is lower than the right by approximately 1mm, but is clearly obvious when you put a straight dowel or similar through the hole for the stab tube.
Regards
Roly
