Pull-Pull controls - Bellcrank material question
This is what I will be using if I use them at all. Simple to make. I just used a micro-bit (can't remember the number) in my drill press. Then I chamfered the hole with a countersink.
After that I chucked the couple in one dremel tool and a brass wire brush in another dremel and spun them together to remove burrs around the hole.
