RE: Prince 25" Mono
Well I put the motor back in and had a bind on it. Also if your drive dog isnt very tight and you tighten up the prop nut to much it puts a ton of drag on it. I got that all straightned out I think.
The square end isnt quite in line with the center part of the flex shaft. Its nice as you can get the flex cable out very easy.
The extra props I bought arent as bad as I thought initially. Took it out of the package and they are ok for plastic. More importantly they are 4MM shaft props, the right size!
Im going to get a set of batteries on order thru the bay soon and need a receiver.
